Thats more of a personal thing with tires and the
way the car is set up... I've run 3 different brands...
M/T, Hoosier and Phoenix... I got the most passes out
of the M/T... got the best 60' on the Hoosier with
the Phoenix right there also( 1.19 60') but got less
passes with the Hoosier and Phoenix... I can pretty
much tell you how many passes are on the Hoosiers based
on the 60' numbers... I get 25 passes at 1.19, then
another 25 at 1.20, 25 at 1.21 and it will stay right
around 1.21 to 1.22 till about 125 passes total, then
it falls way off to like 1.26... I dont do the big
burnout thing OTHER THAN the first burnout when new...
even when I pull the tires off the tread surface has
a good bit left but the side walls dont work for me
any longer... and I use tubes on all of them
![](/ubbthreads/images/graemlins/wave.gif)
