Quote: Well thanks for all the ideas.! But he will have it done without stroking it or big compression staying at 10:1 when the dyno is done i will post the results i bet there is going to be 600 +
Well, I really do believe your friend has made a wise choice. Sometimes this stroker stuff just gets out of hand.
Even though this example is not a Hemi it will illustrate how easy it is to get to 600 HP. 451 wedge, ported 452 iron heads (290 cfm), M1 single plane, 950 cfm 4150, solid street roller 254/260 @ .050, .582/.588 lift, 9.5:1 compression, 621 HP @ 6100 rpm and 588 lb-ft @ 4600 rpm.
If you friend can do anything at all with porting the heads, he will kick this 451's butt.
