Have had it done by guys that know what they are doing and have had no problems with it. Thing to do though is use screw in stud instead of the knurl shoulder press in studs. It takes a much smaller hole to tap threads in that to have an over-sized hole for the knurled shoulder. Using the screw in stud leaves you a lot more meat on the outside of the stud.
