I have a complete Hotchkis suspension system for an E Body Im building.
I do not have the shocks yet.
I see these Bilsteins on the Hotchkis website:
http://www.hotchkis.net/rcd_shocks_dodge_a_e_body_4_pack_stock_height_cars.html
Should I get these, or are there any better choices out there?
Or a choice that gets you more bang for the buck?
Not really a better choice for bang for the buck.
What is your intentions for the vehicle?
If you want to make it an ultimate dedicated full time track car, you can spend $4K on a set of shocks and then go UP from there. But you will have to have the rest of the vehicle up to that level to take advantage of them.
I guess you are right, Ill just get wat they reccomend. Yes, everything is done to that level...,makes sense.
To what level? Do you just have a TVS System?
$4K+ shocks would be on an racecar or almost racecar with full rollcage, race tires, etc etc.
