Wouldn't the "MAX DIA" be stamped on the drum?
That too ...
if the car has original front disc brakes then that would be a 10" rear drum setup assuming nothing is changed.
But as said PULL it off and measure it ?? we can't do that from the internet and the 11" drums look similar to the 10" that year .
