Yes, 4 or 5 ar relays, extra pin (blade) does not have a wire going to it on back
One little ditty I just remembered. When I crossed the starter terminals the second time, I was pissed off and it was dark.
I had a good light show...:) could I have fried anything?
There only the pos from bat and the pos for solenoid from relay.
RSR,
"Put a test light on positive coil terminal with wire connected. Crank and leave key in on position. Should have power.
If not, look upstream according to the wiring diagram"
Can you clarify that?
The coil has the tower post going out to dist and a plug
on bottom with with two small ga wires. I assume one of those should
be hot with key on or cranking and the of the other from CPS for trigger. Do I test those while they are actualy plugged into coil?
Thanks 1000X.
I'll look up stream today.
