Thanks,Ron! Mighty kind of you..Al,I may take you up on that..Here's to both you guys! Ray...The engine has been together for two years so it is possible that there was a seal failure..No ones fault,things do happen! Last year Jim did the suspension and tranny..
Need your rear end checked out? Contact Grizzly!!
