http://www.moparts.org/Tech/Archive/elec/3.html
This should help. Check the tech section
Helpful, but that's if you have an ignition switch. I'm using a remote starter and I know there was something about a jumper wire across the ballast??
Grandma always said I had "hands of gold"!
