Talk to Jim at Racer Brown tell him your engine build and he will make you a nice cam. Since you are going to use adjustable rocker arms you should step up to a small solid cam (app 528 lift) he made a couple of cams for me and I had less trouble with the solid cams than I did with hyd cams. (three collapsed lifters). He's a very nice guy to deal with.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
