I run an old Electromotive TEC II with distributorless ignition. You can see it on the firewall in this pic.
It was a pretty advanced system for it's day. The biggest problem I had was the lack of support for it. Very few people know how to tune it. Unlike the EZ-EFI systems, these are compatible with up to 3 bar MAP sensors (30 psi manifold boost).
The TEC 3r is a more modern replacement. I haven't looked at the software for it so I can't comment on how it works.
www.getfuelinjected.com
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
