It will either be an 055 , if 3.54 geared or an 054 if 4.10. Did the car have power disc brakes ?
What's odd is the car had the bendix power booster
and disk brake master w/ drum brakes up front... Don't know how or why.
Do the master cylinder lines exit on the driver's or passenger's side of the master cylinder?
From what I've seen if it has discs front then the lines exit on the passengers side...drums on the driver's is that what you are saying when you say it has a disc master cylinder?
