Re: 451 low deck
[Re: buck440]
#1114820
11/16/11 01:24 AM
11/16/11 01:24 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
not sure if this is where i ask this question but here we go. guys i was wondering what is all envlved in building a 451 from a 400 besides the grinding of the 440 cranks mains. is there block or cylinder notching involved? pics an all the technical specs would be greatly apreciated. an what kind of power are these capable of?
You need to cut down the counter weights a good .120" to clear, no block prep needed, There is good power to be had in a 451 lowdeck, mine was a very simple build with FTs, XE284H, headers, M1 single, 750dp, 4.10 gears & 4400 stall, in my 75 Duster it pulled off a 10.91 shifting at 5600, race weight was just below 3100 lbs., weight is your worsed enemy, so keep the car light & you'll be happy.
