Mild street build, it's hard to beat a Eddy Thunder, I've run both 650 and 800's The carbs just plain work. On more agressive cams where the vacuum signal is weak Holleys are a better choice. Really like the Eddy RPM or if you need just a bit more hood clearance try a Holley Street Dominator intake.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
