That is the same pump as a jeep cherokee with a 4.0, the 94 wrangler pump is remote resevoir and the same style. I like the older pumps, they seem to last longer, like one you would find in a 70-90's GM or Dodge truck. It helps to have a cooler too. If you want that style of pump, check out Vanco's site and PSC
