As John said Motor Home head, not all motor homes got it, it has a water passage around the plug.. Die grinder would be a bad idea...If you look you can clearly see it uses a tapered seat plug not a gasket type plug...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
