Re: Need basic schooling on fusible links, please
[Re: cdstl]
#1109851
11/09/11 01:20 AM
11/09/11 01:20 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I was at NAPA and asked about fusible links. They were in a book and they can get them. Any idea about how they would be marked? By Amps or as you said wire size?
Thanks,
FLs use a specific type of wire. Don't know what kind - others may be able to chime in, but it is rather flexible and different than regular wire.
As to wire sizing, there are wire gauge sizing charts on the backs of some wire packages, and probably lots out there on the www. that can give the right wire size (and FL size) to use on a circuit, if the load is known. A search like "12V wire gauge table" or similar might get you something.
