Putting frame connectors in a unibody goes a long way in strengthening the frame to reduce flex and improve weight transfer. Either style needs to be topped off with at leat a 6-8 point roll bar for even better efficiency. I'm just guessing, but with a unibody, you can add reinforcements only where it's needed most to save weight.
