Any Chrysler mechanics out there that know what this code stands for??? My wife said she was driving down the road and the truck started to shake a little then she just pulled over and the truck shut off and wouldnt start back up.This code is not listed in the Haynes manual
Thanks for any help..
The PO700 will not keep truck from running!
Beings I own a Durango, they do have issues with connections so check all the connectors . and the o2 sensor wires can get to close to the exhaust and melt wire together.
good luck,
A good mechanic can run the tcm amd ecm on that truck, and tell you exactly what needs to happen here, anything else is a guess !
