Just had to replace my switch as it failed. You have a 3 prong one - right?
The center is the neutral safety prong. To check continuity, check from the prong to the tip (metal part) of the switch. You should have continuity. You don't have to press it in.
The outside 2 prongs are for backup switch. Not sure how to check those.
67 Coronet 500 9.610 @ 139.20 mph
67 Coronet 500 (street car) 14.82 @ 94 mph
69 GTX (clone) - build in progress......
