I haven't checked it for cracks yet....nothing turned colors, the bearing just failed.
Maybe from when I smashed the oil pan.......but it sure took a while. The Oberg filter saved the motor.
The stock cranks are known for cracking around the fillet at lower HP levels than that. I'd have it check first off and go from there.
