You'll find out you should have a few extra needle/seat assemblys around for just such an occasion...The O rings will dry out after time also and sometimes you can get away with just changing them out...This is common especially with the fuel we're forced to use today.... One of the points I perform is to always take the air cleaner off and watch the carbs on the fire up every time...On every classic vehicle no matter how many carbs it has...
