Going on 8+ years all in the 10`s at 3200lbs. and I run the 742 case w/Richmond 4.11 gears, Dutchman 30 spline axles, stock caps and a backbrace.
LUCKY...Is correct word in this post.
The time is going to come when all of you 10 second cars hook up 1 good time and the weak link is going to cause you to spend lots of to fix you Trans/rear/and maybe the motor.
You all need one of these...
Guess I`m lucky I dont hook up good then even though I see 6"`s of air under the ft. tires.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
