you might find some of the original seals have come off the guides. they are not a high quality seal and they're pretty big on the o.d.
Had that issues with several of my eddy seals... but I also had sticky valve guides as well until they were all cleaned up/machined... switched to comp cams .530 seals. Perfect fit and no clearance issues with my dual springs for my roller.
