Mike I had my 1050 converted to a 2 circuit using blp blocks and boosters and it made it work really well on the street, might be worth a try if you want to use a dominator. I gave them all my specs and it worked well just dropping the parts in.
Yeah IF I do go with my 1050(8896) I will change it to a 2 circuit .... I might not need the 1050 since I'm limited to 10.0... but I'll find out
