Tight quench meaning deck the block mill the heads????
probably deck the block,the right pistons & gasket to get .035-.040 piston to head THATS CRITICAL & you need closed chamber heads. I remember a build from WAY back. 73 duster 727,4.56 dana. 440 with 6pack pistons 2355, .030 ~9.5-1 cr 906 heads ported with the DC porting templates 2.14 & 1.81. holley street dominator intake 750 4779? holley DP carb pro parts headers dont remember the converter, 509/292 MP cam. ran mid tens & was(somewhat) streetable. 511 HP on the dyno!
