I replaced the fuel pump, filter and lines after the car died out on me and I had to floor the car to get it home, not exceeding 20 mph. The lines were badly rusted and clogged the fuel filter. The pump was replaced after the lines and filter because I was barely getting any fuel to the carb. Before it did this the car ran great at all rpms.
Thanks!
Ok---great info. What pump did you put on it? And the post above about possible crap in the carb might well be the problem.
