I have a hand full of them,they are different lengths and have the D-hole clocked in different positions depending on what it was from.
i think a 518 that had a cable would have the lever with a ball stud,I have 1 of those in the stash from a 94-v/6-904 tbi tranz.
you need one?
are you talking about the TPV lever or the band lever inside the pan?
The throttle valve lever on the trans. Yeah. I have a 518 lever. I'm thinking since my whole combo is custom that the 516 lever will work just fine with my lokar cable setup with proper adjustment no?
Thanks for the response.
