There was some soft black caulk under the rubber part. The other thread is good and was posted after I started posting mine. I did not need to grind down my posts to remove the pot metal part - the material was soft enough to shave off small pieces around the edges with a sharp tool. As mentioned in the other thread, there's another set of unused posts.
If you don't see two dolphins, you need a vacation.
