The one that I use now is from a '90 Dakota. Maybe it's just plain worn out. It's a pain in the butt to change mine. I don't want to do all of that work for the same result.
Are your headers near starter? Your installation might be heat soaking your starter. A sheet metal heat shield might help your situation.
Yes they are. The one tube comes within a little less than a 1/4" of the starter. You may be on to something. I had thought that around 1/4" would be enough clearance.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
