Judging by the fact the front tire is not turning in the air. You are looking at a change at the rear.
P-body suggested raising the rear tire pressure. I am just wondering with low tire pressure you would get some roll with the front tire as the rear tire is wadding up. Second guessing this you might even try a lower pressure. I still say if you tightened the front shocks. Try front travel limiters as some shocks just don't get it done.
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
