On a 1968 Charger the thing that people ASSuME is the proportioning valve is nothing more than a distribution block, the same one is used for both drum and disc brakes with an extra valve added into the rear line when the car is equipped with disc brakes.
The proportioning valve didn't appear on a B body till the 1970 model year.
