Quote: Mike. I bought the engine used. I don't know how many miles are on it. I bought it to build for the procharger There isn't very much where on the housing. Any suggestions on it,
I agree that the housing seemed torqued down to far. It was tight taking it off
Not sure what to do on the rebuilt. I need to decide to pull apart and clean it up, put together or built with lower compression for the procharger
You could mill that flat again or if you dont have a mill use sand paper on a flat surface like a surface plate of a piece of glass
