Use the same brand and color code type that it was painted with originally.
Every brand is a slightly different color.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
And along that line of thought MOST of them are "pretty" but not the 100% correct shade of orange the factory sprayed, so if you are trying to match original paint you'll likely need a special custom match made up to your original paint, a match is not very likely with an off the shelf mix.
If you are doing the entire engine the closest match to original I've seen is sold by Frank Badelson in pints and quarts, the color also varied by year, 1964-1968 was Race Hemi Orange (with some possible early 69 cars getting it as well) and 1969-1971 was Street Hemi Orange.
