If the kill bleeds are not drilled (can be fixed if they are) and you have the correct metering plates and center metering block there is no reason to replace the carbs.If the air bleeds have been modified that can also be fixed.Have someone who knows 6pk carbs check them,you'll save yourself a lot of $ compared to buying a new set.
