And what about that air cleaner seal? It seems strange to me that after taking off and refitting the air cleaner, the car starts running better or worse, depending on how you put it in there... There's quite a high seal under the cleaner - maybe the problem is there? What about throwing the seal away? I had air cleaner without any seal on many cars and it worked just right...
