Engines that have rod/crank bearings undersized for the expected load (boost on an original n/a motor is a good example of this) will require a heavier weight oil.
I'd consider expected oil temp & bearing clearance the other critical factors.
'18 Ford Raptor, random motorcycles, 1968 Plymouth Fury III - 11.37 @ 118
