I am researching socketless hose ends. I need to get a 90 and possibly a 45. 8-AN to socketless.
It seems like everything I run across is a solid one-piece fitting. I want to make sure I can position the hose end where I need it to be. Otherwise it will be dumb luck that it ends up where it needs to be as I tighten it down.
Am I reading the descriptions correctly or do these fittings actually "swivel" to allow positioning of the hose end?
http://www.summitracing.com/parts/FRA-209008-BL/?rtype=10Oh, BTW, these fittings are expensive! Crazy.
Thanks.
