Height: 2.80 inches
Length: 5.10 inches
Width: 4.10 inches
Found these specs....Hope it helps
Thax. 4 those dim.
Anyone running a crank trigger with the pickup on the left side of the engine were the oil filter is?The problem I'm having is clearance problem between the filter and crank trigger pickup what r u guys doing to get around this problem pic's would be good.Thax....
