Whoops, I'm sorry. I should have been more clear. I mean I was thinking of using the Magnum pistons AND rods in the LA engine. Would that work, or is the rod different on the crank end as well? The only reason I ask is because the magnum engines are rated as being 9 to 1, and the LA is 8.5 to 1. I don't know if the magnum heads on an LA block would boost compression, or if the magnum chambers are around the same size as the old 70s 318 LA heads.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
