You didn't ask... but I'll add. Its hard to beat the mechanical fan. A thermal clutch with a 6 or 7 blade fan and shroud moves lots of air... more than the dual setup you are looking at I'd bet. On heavy duty applications, that's what you see even on newer trucks. No super heavy electrical loads either and will save (I'll guess) $200+ on a suitable upgraded alternator.
