check the front damper on the 77 440,is it a thick bullet shaped and have cast crank only on it?
may have to R&R the pulley from it to see
the spline count and the cast crank are what they need to know.
like siad a local tranz shop should be able to weld the weights on or just get a reman TC from them.
