Not that that is a bad bov, but just to point out, it is a knock off of a god speed knock off. I would love to see inside it. I just would hope that o ring is not the seal.
I got it from God Speed! No it does not have an O-ring.. It has a reinforced diaphram that is a good piece. I did a bench test after I disassembled it and it held at 40 p.s.i... I also got the same wastegate and it had a torn o-ring in the adjustment on top. Polished the stem and added a new o-ring and bench tested to 40 p.s.i.... NO problems....
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
