I assume you have thought of this,,,but do you have the correct right and left torsion bar for the driver and passenger side ?
If I read it correct, i think he means that in order to get the torsion bar in the lca socket, it hits the header tube. Either the headers are not made for this app., or the k frame is not built exactly to factory specs and moved the lca mounting point slightly.
Can you take some measurements with a plumb bob to a level floor and compare to a stock car?
1.50 60Ft. , 10.75@ 127MPH Hauling 3900 LBS.
