Quote: Quit whining and just get it done....Dammit
Rickster
My goal is to have the full front end installed by Monday. To accomplish that, I have to: 1. Finish making the return hoses for the steering and hydroboost. 2. Spray Monstaliner in the the front wheelwells. 3. Respray (yes, repaint) the front grille. I had discovered an area on the front of the grille where I had missed the final 400 grit sanding, and it has visible sanding scratches. Unacceptable! So, I have to smooth that area flat, scuff the whole thing, and respray it with two coats.
Tonight, I cut off the bulges on the return ports, and installed -6 AN adapters.
Gone to the dark side with an LS3 powered '57 Chevy 210
