Sounds like you need to raise the front end up a little or run a taller front tire or... Get a shallower oil pan...
Its a self shallowing pan if he does that any more
put a taller tire on unless you have good reaction
times now... if so either raise the body up or a
shorter pan.... you could add a skid plate to the K
member to protect it
