Re: Seat belt retractor box installation
[Re: DAYCLONA]
#105898
08/17/08 08:08 PM
08/17/08 08:08 PM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
The units should face forward about 22.5 degrees (you want that OEM gold certificate... right? )... 30 degrees you might slide by?... in my T/A, I glued the carpet down on them, at the same time I istalled the outer plastic strap guide,.. I think trying to locate them, then glue, then return them back into position you might have problems... think how many seconds the original assy line worker had to install them?
Thanks Mike. The last part makes a lot of sense.
Until total honesty is on the table, we're not even talking about reality...
