You can bolt the 4 bolt covers onto the late model 6 bolt heads, you just won't have bolts in the two bottom head bolt holes. The gaskets will seal the holes closed. Then you can use the much better later heads, unless you really need to stay with the 4 bolt heads. I doubt any 4 bolt heads are any better then any other 4 bolt head. Gene
