It's not that the cross ram will not make any HP just not as much as a good single plane. Sell the cross ram to someone that needs it for a nostalgia super stock if its modified or to someone doing a restoration if is unmodified. The cross ram intake will bring enough to buy a good single plane and a new carburetor.
On my 64 car that weighed in @ 3150 lbs the EZ heads with MW port and an oe cross ram on a 493 ci I did get a best of 9.98 but most times it ran 10.10 to 10.15 in the 1/4.
Russ
