Can't help you on the master pn but an observation... with the big assist from the hydroboost plus a small master diameter, you will be able to generate crazy high brake line pressures. It could be too much for the lines and wheel cylinders/capilers. Suggest you contact Hydroboost and ask minimum recommended master diameter.
