I got a few PMs the last time I posted this, and alot of opinions. My external fuel pump was mounted along side the gas tank, however it was mounted to the trunk floor on the bottom of course and started making noise about 2 years ago and finally got loud enough for me to change it. Some of you say it needs to be mounted lower and some say, it makes little differance, so I had some brackets made to lower it to about even with the bottom of the gas, but it is kinda hangig out where it could get hit by something and thats my concern. I would rather replace a pump every couple years and have it tucked up high then take a chance something will hit it and then I could have an issue? Any opinions?
